Machine Vision
photo camera with pci 1411
I checked several posts for image aquisition but I did'nt understand wether I can use a digital photocamera with my PCI-1411. We have to take pictures regularly timed and we have available a compact photocamera and a reflex one (Canon 500D). Would a converter S-video to USB be anough to connect the camera to the PCI-1411?
Any suggestion is more than welcome!
Giacomo
(3,796 Views)
Hello Giacomo,
Can you give some more information about  the complete project?
Should the camera be triggered by the pc or does it automatically produce a digital output feed?
The PCI-1411 (https://www.ni.com/docs/en-US/bundle/374550a/resource/374550a.pdf) expects an analogue signal at its inputs.
This signal should one of the following two:
- Composite video on BNC (RSE)
- Y/C on S-Video connector (RSE)
As far as I know, the Canon 500D is a digital reflex camera, so you should find a way to get an anlogue feed out of it to be able to use the PCI-1411.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,789 Views)
Hi Thierry,
thanks for the fast reply and useful info!
The camera should be triggered by the pc in order to get a picture every minute in .tiff format. The images then will be then processed to recognize particles shape and distribution.
The canon eos 500D has the following connectors:
• USB 2.0 Hi-Speed
• Video output (PAL/ NTSC) (integrated with USB terminal)
• HDMI Type C
therefore I though we could use the video output to go to the PCI1411. But here I'm doubting on how to make the connections. The PCI1411 has three plugs (i.e. video, s-video, trig) and I'm guessing I have to connect the camera to the s-video and the trig port, but I don't see any cable which could do all of this.
For the moment I'm waiting for the PCI1411 to be delivered to me and I cannot try practically, but I'm trying to be prepeared.
Thanks again for any suggestion and tips!
Giacomo
(3,786 Views)
Hello Giacomo,
I have been out of office for a few weeks because of holidays and courses.
Do you have User Manual/Spec Sheet of your camera available that I could use to look up the information you specify over here?
Kind Regards,
(3,762 Views)
Hi Thierry,
thanks for your help and interest!
We currently have two cameras and the possibility to buy a new one if necessary. The manuals of the two photocameras:
1 - a compact one with which the PCI1411 probably wont work http://download1.medion.com/downloads/anleitungen/bda85863denlfr.pdf
2 - a digital reflex from canon http://www.evergreen.edu/medialoan/docs/photo_manual_rebelt1i.pdf
In case the both wont be able to communicate with the PCI1411, which are then the specifications of the camera one should look for?
Looking forward for your reply, I thank you again and wish a nice day.
Greetings,
Giacomo
(3,756 Views)
Hello Giacomo,
Sorry for my late reply.
The flu and some other issues came in the way.
To be able to acquire images wit he PCI-1411 the only restriction is the type signal you're providing to its inputs.
In the User Manual (https://www.ni.com/docs/en-US/bundle/372157d/resource/372157d.pdf) You can find the 2 different supported types at page 3-2:
- (Composite) Video
- S-Video
More info can also be found in this document (https://www.ni.com/docs/en-US/bundle/374550a/resource/374550a.pdf)
The NI 1411 device supports both
NTSC and PAL color standards as well as the RS-170 and CCIR
monochrome standards.
 So what you'll have to check is:
- Is there an S-video or Composite Video output on my camera? (I don't think this is the case with your cameras)
- Can I somehow convert my signal to S-Video/Composite Video?
There exist things that you can buy online for this.
Normally you can use any camera that has these types of outputs and that follow these standards:
- PAL/CCIR (25 frames/sec)
- RS-170/NTSC (29,97 frames/sec)
Kind Regards,
(3,747 Views)
