Machine Vision
pressure foil
Hello, I must be in the scope of my degree thesis data from a scanned image readout.
I work already for several years with Labview, but only now begun with Vision.
The displayed image comes from a pressure measuring foil (Prescale from Fuji) like mine.
Angehängtes Bild
195 x 200 (9.06KB)
The color intensity is on the surface resulting pressure.
The reference foil gave it a color scala with the press in bar.
Now I need help. I want the color values of Scala, or as an integer array values drop and cuts (with a ROI) of the pressure measuring foil to compare and Labview should say how much because of the pressure at this point.
My problem now is how I can compare the values. So i find nowhere good tutorial or help find. Although I know how I must begin around, but VI's not what I use.
While I did all Exsample VI's done, because look but not entirely.
I use LabVIEW 8.5 and Vision Development Module
Thank you in advance for the help
Message 1 of 1
(3,310 Views)
