Machine Vision
problem with thresholding
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 11 of 18
(3,698 Views)
Thanks a lot It worked . I was unaware of unbundle thing .
Message 12 of 18
(3,694 Views)
Just curious to know why you would want to convert it into array
Message 13 of 18
(3,692 Views)
Yeah, me too 🙂
Message 14 of 18
(3,688 Views)
Most of time background countain noise in case of x-ray images . By taking avg ROI values and subtracting it from images we can reduce noise.
Message 15 of 18
(3,687 Views)
I still didn't get threshold thing right. You said connect  destination of threshold to U16 bit but after threshold it will be binary right but there is no option to select binary for destination image.
Also roi values can be useful in calculation of flow if you have many frames of images and contrast flowing through it.
I really appreciate help from you guys
Message 16 of 18
(3,684 Views)
Having worked on X-ray images. You are getting a tiff image right? You can actually use a filter on the whole image and do contrast enhancement . (Just guessing without seeing the image)
Message 17 of 18
(3,682 Views)
No connect u16 to image desitnation of threshold
Message 18 of 18
(3,680 Views)
