Machine Vision
programatically extract x,y posisition found by Vision Builder pattern match
I would like to write the cordinates found by doing pattern match to a file.  Can this be done with the Vision Builder?
(3,594 Views)
Yes you can.  Just use a pattern match step, then a Data Logging step. In the data logging step, you can specify what all you would like to write to file, and the results from the pattern matching step, including the coordinates of the match pattern.
Cheers,
Marti C
NI Medical
(3,575 Views)
Thank you
(3,566 Views)
In the following we proceed to function block search pattern extracted in the previous process (the parameters as rotation angle and minimum score is inserted into SETTINGS control), extract the output of the search function to get the position values indicators that will be displayed on the front panel)
(3,043 Views)
