Machine Vision
programmatically setting the frame rate of a webcam
Did you check this solution???
http://forums.ni.com/t5/LabVIEW/Programmatically-Set-FPS-using-NI-IMAQ-with-a-GigE-Camera/td-p/21590...
and did you check the example grab and attributes setup in the shipped example??
-I see it is possible to set fps programmatically using property nodes and acquisition attributes, provided camera allows.
uday
Message 11 of 16
(2,853 Views)
Yes......i had checked that site ,however my webcam cannot be opened using imaq-dx....i use imaq usb instead and sadly i could not find a property node to help me set the frame rate......however your solution seems to be working fine
Message 12 of 16
(2,841 Views)
Hi you can do the same in IMAQ also.
Go to Camera Control in IMAQ and use IMAQ set camera attribute. give your atribute name and value.
uday
Message 13 of 16
(2,839 Views)
hello,
i gave it a shot but not compatable...i guess it's because my webcam is not seen in max....anyway here's a clipping and the error i get....ex-1.jpgex.jpg
Message 14 of 16
(2,831 Views)
Sorry for misunderstanding. It looks like NI has discontinued IMAQ usb and integrated same support in IMAQdx for usb cameras and it has lot more features in it.
uday
Message 15 of 16
(2,827 Views)
hallo,
What is the vi icon used before the vi actual loop frequency. Thanks
Message 16 of 16
(988 Views)
