Machine Vision
"EventsGeneration" on Basler Racer camera (genicam events)
I tried to know if my camera has overtrigged using the event generation functions of the camera (p.171) but I can't find any examples.
Those attributes are not readable/writable : AcquisitionStartOvertriggerEventData & LineStartOvertriggerEventData
Let me know if you had experienced with events using imaqdx and genicam events.
An Event Type Identifier. In this case, the identifier would show that a frame start overtrigger type event has occurred.
A Stream Channel Identifier. Currently this identifier is always 0.
A Timestamp. This is a timestamp indicating when the event occurred. (The time stamp timer starts running at power off/on or at camera reset."
Thanks you
Patrick
Message 1 of 1
(1,465 Views)
