Machine Vision
"Make sure all of the VI dependencies (including vi.lib VIs) are located in the same LLB as the VI you specified"
Hi Brad,
I checked both the "Remove unused members from project libraries" and "Modify project library file after removing unused members" and the build now takes just seconds. So it works fine now.
Previously I unchecked "Modify project library file after removing unused members" because I follow the instruction in the FAQ - since it says "disable" this option if you use a version of LV earlier than LV2010. I am using LV2010. Strange but nevermind... problem solved!
Message 11 of 11
(846 Views)
