Machine Vision
"NI-imaqdx devices" folder not showing up in NI-MAX/USB Cameras not recognized
Imperx IPX 1M48 L camera with a framegrabber of Teledyne dalsa X64 CL iPro.
We do not have support for your frame grabber.  We only support National Instruments frame grabbers.  You will not be able to use a Teledyne Dalsa frame grabber in MAX.
Message 21 of 24
(2,304 Views)
Thank you.
Message 22 of 24
(2,281 Views)
I faced a similar problem like the one you shared with the community. I searched a lot on google and at last found the solution to the problem on this site. Emergent VisionTec have the best on site solutions to problems people usually face while using machine vision cameras.
Message 23 of 24
(2,276 Views)
Hi, I hope you're fine.
I'm facing the same issue but not solve by renaming "niu3v". Figures have been attached. USB-cam has shown in NI MAX and properly work but not working in NI-IMAQdx devices.
Message 24 of 24
(1,582 Views)
