Machine Vision
reading timestamp of dalsa genie M1400
Hi Eric,
the timestamp problem is solved. I change the driver to the NI gige driver and since that time I've no troubles with your timestamp program anymore.
If I had known that the NI gige driver is a high performance driver I wouldn't have changed it back to intel driver after installing the LV IMAQ acquisition software. But now it's running.
Christian
Message 11 of 14
(1,602 Views)
Could I please get a copy of the VI to read the meta data from the dalsa camera , I have a dalsa HM 1400 and would love to move away from the software supplied with the camera as its hard to automate my testing with it.
Rob
Using labview since LV 8.6 , Great Stuff 🙂
Message 12 of 14
(1,323 Views)
Hi Rob!
I finally hadn't used the timestamp program for my application. So I didnt spent to much time in documentation. But I can remember that it really worked and I found some VIs from Eric and hope this helps.
Christian
Message 13 of 14
(1,318 Views)
Thanks ,
This is why NI software is so great the support of the users Smiley Very Happy
Thanks again
Rob
Message 14 of 14
(1,311 Views)
