Machine Vision
real time image recognition
Hi
I have corrected the input path of my pattern png file and now I have the following error.
Error - 1074395247 occurred at IMAQ Match Pattern 3
Possible reasons:
IMAQ Vision: Invalid template descriptor
Message 11 of 15
(1,760 Views)
Well,
You get this error because you probably provide an invalid template file.
you have to know that the template is a special image file.
It is in fact a png file that contains also some informations used by the matching function.
You have 3 options to get a valid template png file :
  • Use the one that you previously generate with vision assistant.
  • Create your own one within LabVIEW with the "IMAQ Learn Color Pattern" function and save it with the "IMAQ Write Image And Vision Info File" vi
  • You can also use the small editor provided by NI. See below:
Message 12 of 15
(1,754 Views)
Hi
I don't think so. The template file is correct.
Message 13 of 15
(1,735 Views)
Hi
This is my new code. There is no errors now but the number of matches is always 0. I would like to mark the matches somehow (with red rectangle par example) but till the moment I have no success.
Please help me.
Message 14 of 15
(1,723 Views)
Look at the pattern matching examples that load a template.  There are one or two steps for loading the template, which is usually done one time outside the loop.  There is also a step for setting up the pattern matching, if I remember correctly.  Inside the loop, you use the acquired image and template image to do the actual search.
Bruce
Bruce Ammons
Ammons Engineering
Message 15 of 15
(1,711 Views)
