Machine Vision
record session
we are looking into vision
What we are looking for is to see a movement and ,we want to attach angle and dsiplacment from the object
is there a possiblity to record these values in time  a so called history with  as it possible the object
Example let say we want to analyse a golf player  and want to see all angles of interset as well the stick
Can we run a camera and see the ANGLES life and analyse it afterwords
all help apriciated   we stuck with this one
cees
(3,386 Views)
My understanding and suggestion
You can detect the golf stick if the background is really different in contrast. Once you are sure this is available we need a camera that will snap high speed images. You can display the final image and merge the overlay from all the previous images. Lets say straoke start to stroke stop. Display the stroke stop image and display the overlay of the rest of the images (this depends on the camera)
(3,379 Views)
