Machine Vision
retrieve camera properties from camera using CameraFileGenerator
I got today a camera link interface PCI-1426.
Using Measurement and Automation, I can already retrieve images.
And with the CameraFileGenerator, I can adjust setting defaults and setting range when these are different for my camera.
Is it possible (how?) to add with CameraFileGenerator camera properties that are "get" controls ?
I like to retrieve the camera type from the camera itself and I know which command to send.
I like to retrieve current camera settings before sending a reset command.
But I do not know how to enter such read-only strings/values in CameraFileGenerator.
Jos
(3,508 Views)
You can send commands that get info from the camera, but there's not really a good way to use it in the camera file. I would recommend doing this in a programming language. You can call NI-IMAQ functions to send serial commands and read serial responses from the camera and then do operations programatically based on the camera response.
Hope this helps,
Brad
(3,504 Views)
Thanks Brad,
The information helps, but also it doesn't.
I want to access the camera from within matlab. But as this is not going as smooth as hoped for, I wanted a button for myself and other users in Measurement and Automation that retrieves and displays some camera information. At this moment I only see buttons to send new values such as gain and exposure time.
Thanks anyway, Jos
(3,492 Views)
