Machine Vision
scout camera attribute not setting
I am using basler scout Gig-E camera , In this i un configure the acqusition first then setting the camera attributes like(shutter ,Gain) then configure acqsition , start acqustion   this is the procedure i am doing for changing the attributes ,If i am doing like this camera attributes are not geetting changed.but After start the acqusition if i am try to change the attibute setting its apply to the camera.Whre i am mistaking pls reply to me?.
(3,609 Views)
Hi Jaffer,
See forum item:
http://forums.ni.com/t5/Machine-Vision/scout-camera-attribute-not-setting/td-p/1143629
see kode in attachment :
test-basler.zip
In VI:   test-1-cam-speed.vi  all settings are done.
Hope this helps,
Toine
(3,440 Views)
