Machine Vision
setting maximum number of image buffers in MAX in IMAQ vision builder
To aquire large number of images using duncan Technologies Camera (7f/s) on IMAQ PCI 1424 i'm supposed to set the maximum number of buffer images in MAX(Measurement and Automation)in IMAQ vision builder. But i do not see the option for specifying the maximum number of image buffers under the properties of PCI 1424. Please advise.
Thanks in advance.
(3,325 Views)
The setting is somewhat difficult to locate.
In MAX, select "Tools" on the main menu bar. Under that, select "IMAQ". The only option that comes up is "Max number of buffers".
Bruce
Bruce Ammons
Ammons Engineering
(3,325 Views)
