11-02-2006 10:36 AM
In the attached file you can see the acquisition that I need to make.
The camera that I have is Jai CV A11 that should work in frame reset.
My higher frequency is 10 Hz (5Hz/pair of cameras).
I hope that this can be done in DMA, because my code is quite heavy.
I believe that the easiest way to make it is to do the acquisition in RGB mode (use the first cam as R and the second cam as G for instance and extact the plans in my code).
Can somebody help me to make the configurations in the camera and in the board?
Thanks in advance, best regards.
Paulo Carmo
11-10-2006
09:29 AM
- last edited on
04-23-2026
09:56 AM
by
Content Cleaner
