Machine Vision
sliding window technique
    I am doing a project in image processing,i would like to know what is sliding window technique and purpose of using it in image processing?.
Thank you
(6,782 Views)
in image processing a sliding window technique is a technique of moving a window along the image, where some image processing is performed on the underlying sub-image. For example image convolution uses a sliding window. Or pattern matching.
See the simple attached example.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(6,781 Views)
(6,731 Views)
