Machine Vision
slim image sensor
Hello!
We are developing a tester for examining the outcoming laserbeam of the pick up unit (OPU) of a CD module. Since picture is captured inside the module a slim CCD sensor is required. Is any type of sensor available with a width of ca. 1mm? Other Sensor parameters are preferred: Sensitivity in IR, 1/3 or 1/2 image size, at least 512x512 pixels, analog output (for NI PCI 1407)
(Endoscope is not a solution)
Can anybody give some tipps where I can find it...
Thanks in advance,
Zoltan
(3,757 Views)
Sorry, a fault in the original question:
 Is any type of sensor available with a width thickness of ca. 1mm?
(3,751 Views)
Good morning!
It think it would be better to contact a camera manufacturer directly to get an answer to your question. NI produces framegrabber and software, cameras aren't in our portfolio!
Possible contacts are: Basler, Jai, Sony
regards,
ThSa
Message Edited by ThSa on 10-13-2005 02:09 AM
(3,730 Views)
Hi!
Yes, I know, that we can't get camera sensors from NI but I trust in the members' experience. Of course, we have tried some manufacturer, eg. Sony but all sensors are thicker than 3mm...
(3,725 Views)
