Machine Vision
smart cam 1742: ftp image logging
Concern: VBAI 2010 + target 1742
I have an issue regarding ftp image logging with targets: If the filename contain one or more space caracters at the end, the extension (.jpg for exemple) isn't added
to the filename.(The name of the image is send by a PLC and contain at the end some space to have a fixed number of caracters)
thanks for your help.
(3,715 Views)
Thanks for posting on NI Forum.
The extension is added when the filename doesn't contain any space caracters??
Nicolas M.
National Instruments France
Journées Techniques LabVIEW 2012 : du 27 septembre au 22 novembre
2 sessions en parallèle : Débuter avec LabVIEW - Développer avec LabVIEW
(3,707 Views)
Yes, when there is any space, the extension is added.
Thanks for your interest
(3,703 Views)
This spaces are important for the filename??
Nicolas M.
(3,698 Views)
No they aren't important but the name is send by a PLC and we can't recieve the name without this space.
(3,684 Views)
If you put your filename between " ", it works??
Nicolas M.
(3,673 Views)
Nicolas M.
(3,673 Views)
