Machine Vision
snap from a simple ip camera instead of GigE
i wanted to know if it's possible to snap image from a simple ip camera (security camera), instead of a GigE vision camera.
the ip cams are simple ethernet cameras.
thanks
(4,569 Views)
With the next release of IMAQdx3.5 (Part of Vision Acquistion Software) it's possible to take images from IP cameras too.
Christian
(4,437 Views)
Christian
That is nice.....
(4,426 Views)
@muks:  I was running a cRIO-9024 with an Axis IP Camera, ....this is nice!
(4,424 Views)
If you want an integrated solution for vision on cRIO instead of the IP camera take a look at this AF-1501 Analog Frame Grabber for cRIO
Cagell
(4,309 Views)
