Machine Vision
some questions about imagetoarray.vi
hello  everyone! I use NI1433accquire board and linear CCD.Now  i want to convert the image to intensity graph,but something wrong is appeared !  I wish someone could offer an example with imagetoarray.vi . PS:I can't find the example in my computer .Hope your answer!
(5,168 Views)
You need to specify "Grayscale (SGL)" datatype as input in the IMAQ Create function since you are processing the data as float.
Leaving the input blank, I think the default is "Grayscale (U8)", so if you use the U8 output in the image to array function, you should see the output...
Why do you need such a large border size -> 1680 pixels?
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,162 Views)
hello!At  the first time,i thought the boader size is the image size .Now i solved thid problem ,Thank you !
(5,139 Views)
