Machine Vision
something wrong with vison auquisition expess
Recently I found that my 'vision acquisition express' cannot work normally, on the step of "finish configuration", it couldn't continued to finish the last step. What was wrong with it?
(3,871 Views)
Your LabVIEW installation is probably corrupted.  Reinstall everything.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(3,759 Views)
Oh, thanks a lot at first. I had forgot to fresh my forum. In fact I have solved the problem long ago. I found that one day I wrongly uninstalled the NI vision Run-Time 2009,which led to the above problem. Anyway, thank you!
(3,745 Views)
