Machine Vision
spatial calibration with LabWindows / CVI and NI-Vision
Hallo Experts,
after digging in the forum for my problem - but didn't find a solution for me - I am finally posting my question. It appears that most posts are working with LabView.
So, here's the task.
 - Assuming an uncalibrated image, containing markers in it.
- The postition of the markers are well known in the real-worl-coordinate system
- The marker position in pixel-coordinates can be retreived via mousclicks.
- Now i want to transform the image from pixel to real world coordinates.
I am able to create a calibration strucure using:
CalibrationPoints* calibPoints;
TransformReport* Transform;
calibPoints->numCoordinates = nrOfMarkers;
calibPoints->pixelCoordinates = imagPixelPos;
calibPoints->realWorldCoordinates = realWorldPos;
imaqLearnCalibrationPoints(ImageIn,calibPoints,NULL,NULL,NULL,NULL,&quality);
Next thing I do after   "imaqLearnCalibrationPoints"  is
Transform = imaqTransformPixelToRealWorld(ImageIn,imagPixelPos,nrOfMarkers);
I had expected that ImageIn is now somehow dewarped according to the real-world-coordinates of the markers, but it appears it is not.
The transform report also contains just one valid point, while nrOfMarkers is 16.
What I am missing?
Please find attached some screenshots indicating the structure of:
Pixel-Coordinates
Real-World-Coordinates
Calibration Points
Any help is highly appreachiated.
Thank you,
der_Phil
(3,290 Views)
OK,
it seems I simply had to do:
-imaqLearnCalibrationPoints()
and
- imaqCorrectCalibratedImage()
After this the input image is dewarped based on the marker positions.
Note: Still we are in pixel coordinates.
Question aside:
Where can I access the position of the markers after using
   imaqCorrectCalibratedImage()  ?
I would like to overlay over the dewarped image the marker location.
Please find attached a screenshot of the dewarped image.
Thank you.
(3,244 Views)
One more hint:
Here is the goal:
In the attachment one can se a line found in the image and drawn in a diagram.
This line is obviously drawn in pixel coordinates, taken from the dewarped image
..see post #2
Actually the goal is to have this line in real world coordinates x/c and y/b, with
0<= x/c <= 100   in [%]
0<= y/b <= 100   in [%]
thank you
(3,239 Views)
