Machine Vision
switch sequence grab
i have to write an application in which i need to switch between "grab image continuously" and "acquire sequence". The camera is hardware triggered by a NI-USB6008 and i can completly control the trigger pulse send to the camera. (i send a pulse every 1 s... the frame rate in low...) The grab image works fine in a loop structure where i read image with the low level get image, but how can i switch to "sequence mode"????
I use LabView 8.5 with IMAQdx library.
thanks in advance
(3,408 Views)
How fast do you need to switch between the two modes? What frame rate are you expecting for the sequence portion of the acquisition? How many frames are you expecting to capture in your sequence? Lastly, what resolution are your images (large or small)?
Eric
(3,393 Views)
I have no requirements on switching in terms of continuity of acquisition... i have two separate process, one for the continuous grab (fired by a button on the front panel) and one for the sequence (fired with another button on the front panel). The two "mode" are independent.
1 fps... i have a cameras hardware triggered by three out of the NIUSB-6008... and i have the process "sequence" working... as the "continuous grab" working... i cannot combine them in a single event structure, or something similar....
10 frames (in about 10 seconds)
1024x768...
Please consider that i have no bandwith problem... and i have the two process working...the process are simply the two example of IMAQdx library:
Low-Level Grab.vi
Low-Level Sequence.vi
How can combine them in an single event structure or in a while loop and how i can switch from one to another??
thanks!!
(3,389 Views)
