Machine Vision
take succession of images from USB camera
Good evening, I have a medical project where i will use labview (vision NI-IMAQdx...) and USB video camera ,and i have a problem ,how can i get a succession of images that separate between them 3 or 5 seconds from a USB camera video,and after that i must to process this images,Please if can any one help me its urgent case.
Thank you.
(3,596 Views)
could you explain exactly what is your means succession
(3,572 Views)
I mean to take a picture each 5 seconds from the video acquiring directly from usb camera.and when you take this picture you can proceed it.did you understand?
(3,565 Views)
check this it help you to solve your problem
(3,545 Views)
I was able to test the VI on my computer and it worked well to the use case.  I'd be careful because this is a simple example that does a great job in showing you that it is possible, but it is roughly based on the Producer Consumer Architecture so be mindful of just copy/pasting the code into your's.
@Hatef nice VI!
-Bear
Ben Johnson
ʕง•ᴥ•ʔง
(3,533 Views)
thank you bear I hope this code solve touitou problem
(3,522 Views)
