Machine Vision
.tif 12bit file read
I have a .tif file produced from a different application (XCAP) that will not open using the readFile vi in the vision development module. I am using LV 8.5.1. The data in the file comes from a 12-bit monochrome CMOS imager. If I open the .tif file in photoshop the data looks fine, and if I resave the file from photoshop then labview will open it. I'd rather not have to open each image by hand in photoshop and was wondering if I am missing something...
The error I get is:
Error -1074395984 occurred at IMAQ ReadFile
  NI Vision does not support the file data type you specified.
thanks for any help!
(3,486 Views)
Hello trneb,
Did you place down the default control for the “File Options” input of the IMAQ ReadFile VI (right-click the input and select Create->Control)? If so, have a look at the “File Data Type” control. In LabVIEW 8.5.1 a bitrate of 12 is not one of the options.
One solution is to save the images as 16-bit in your third-party “XCAP” software. This way you will not lose any quality, and you gain the ability to programmatically specify the proper data type for the IMAQ ReadFile VI.
I hope this helps 🙂
David G
Sales Engineer - SE Michigan & N Ohio
(3,460 Views)
If ReadFile won't read the 12-bit TIF directly (sounds like it doesn't, but that is suprising), you could always use a simple program like ImageMagick to do the conversion to 16-bit in a more automated fashion than PhotoShop. You could either call it manually to convert all files in the directory, make a simple batch file, or simply have your LabVIEW program call into it with a shell execute VI to convert it in-place before opening it with ReadFile.
-Eric
(3,450 Views)
