Machine Vision
track ROI from coordinates
Hi, I am working with Labview to track the movement of a point through a series of images. First, I used Vision Assistant to calibrate the image and match several patterns. Then I used batch processing and saved the pattern matching info to a file. Now I have a file with the location of a certain point throughout all my images. Now, I want to use either Labview or Vision Assistant to watch the tracking. I want each image to be shown with a point placed on the corresponding coordinate saved in the pattern matching data file. This way, I can visually check to be sure that the program is behaving correctly. Thank you!
(3,890 Views)
In LabVIEW, use the overlay functions to add stuff to the images for display, such as circles or lines.  Once they all have overlays, you can display them however you want.
Bruce
Bruce Ammons
Ammons Engineering
(3,885 Views)
But how can I overlay the point at a certain coordinate that I have stored in an external file?
(3,877 Views)
You can create a bitmap and overlay it (handy for + symbol) or draw a circle.  If you use a bitmap, subtract half the size of the bitmap from your X,Y values so it is centered on the point.
If you don't understand overlays at all, look at some examples.
Bruce
Bruce Ammons
Ammons Engineering
(3,875 Views)
