Machine Vision
transmit .avi over wireless link
I am working on a communications project using NI RFSG and RFSA. I can transmit bits over the link. Now I want to transmit a video file . I am new to NI Vision. So i want to know that is there any example or code that converts one video file on the hard disk  into a bitstream and then converts the bitstream back into the video file written on the hard drive.
(3,162 Views)
Hi sabe,
I could not find any examples that do exactly what you are looking for but the ones below should be a great starting point. All you need to do is read each frame from the AVI file, convert it to binary, send the data, convert each chunk of the binary stream, and then save it all back to one AVI file.
IMAQdx Record Video to Binary and Convert to AVI
https://decibel.ni.com/content/docs/DOC-21688
Save 16-bit image to AVI
https://decibel.ni.com/content/docs/DOC-4672
Tim O
(3,151 Views)
