Machine Vision
triggered acquisition with e2v octoplus line camera
I want to do a triggered acquisition from our new e2v octoplus (camera link model). I have it connected to a PCIe1433 board. It needs to be synchronized to a TTL trigger (from a DAC controlling galvo mirrors). That triggering model works for another camera.
With the octoplus I can set the camera to external triggered acquisition mode (using the serial commands), but it doesn't acquire any lines in this mode. When I try this with the CameraFileGenerator I get a message with a timeout. When I try it with NI MAX, I get an error message stating no serial termination character is received.
Do I need to make changes to the .icd file? What changes? (edit: I tried attaching the icd file but it is rejected)
In the end I want to do the acquisition using LabVIEW (the galvo control also runs in LabVIEW).
Aart
(2,412 Views)
Are you connecting the trigger to the 1433 or to the camera?
With camera link it should be connected to the 1433.
Amit Shachaf
(2,389 Views)
yes the trigger is provided to the little coaxial connector at the PCIe1433.
(2,382 Views)
I need to do the exactly same thing. Did you solve the problem? It seems that I need to request .icd file from OctoPlus company.
(802 Views)
