Machine Vision
trouble triggering acquisition - PCIe-1433
I've got a Point Grey Gazelle, camera link, in bulb shuttered trigger mode using a pulse generated at CC1. Everything works fine so far. I've been taking software-triggered sequence acquisition with:
imgSequenceSetup();
imgSessionAcquire();
The sequence proceeds fine, and finishes. Now, I need to use the card's SMB input to start the acquisition. I added a step:
imgSequenceSetup();
imgSessionTriggerConfigure2(sId, IMG_SIGNAL_EXTERNAL, 0, IMG_TRIG_POLAR_ACTIVEH, 100000, IMG_TRIG_ACTION_CAPTURE);
I apply a 5V trigger, and it never starts! imgSessionStatus() always tells me I'm on frame -1. What's frustrating is that if I read the signal using
imgSessionTriggerRead2(sId, IMG_SIGNAL_EXTERNAL, 0, IMG_TRIG_POLAR_ACTIVEH, &status);
I can see it flip between 0 and 1 when I apply the pulse, but the acquisition still never starts.
I think I might be applying things in the wrong order, or perhaps I have a routing conflict. Any help anyone has would be greatly appreciated!
(3,219 Views)
Hi there,
Have you tried to run the Triggered Snap example? In Windows 7, it is installed in "C:\Users\Public\Documents\National Instruments\CVI\Samples\IMAQ\Signal IO". Are you able to trigger with this?
Ravi A.
National Instruments | Applications Engineer
(3,211 Views)
