Machine Vision
two dimensional balckman window
Can anyone help me to create a two dimenstional Blackman window of size say 256x256 using C language
Thanks in Advance
Gigy
(3,699 Views)
Hi Gigy,
Are you using Measurement Studio? If so, there should be some built in functionality for this. Are you using it on a DAQ board?
Dan
(3,690 Views)
I am using IMAQ libary. I need to mask the image before doing any image processing. My intention is to create a 2 D array of size 256x256 and convert it into an imaq image and use it for futher processing
Let me know how to create a 2-D blackman window in C language and convert it into Image structure by using the array-to-image inbuilt function in the library.
Thanks in Advance
Gigy
(3,687 Views)
Hi Gigy,
You might try some masking examples that we have posted here:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3D90656A4E034080020E74861&p_node=DZ52513&p_source=External
Regards
Dan
(3,674 Views)
