Machine Vision
two point image calibration calibration in labview.
I need to do two point image calibration  calibration in labview.
using run labview step.
both pixel and real world values are from config file.
How to do two point calibration?
(4,979 Views)
you can use "Set Simple Calibration" to specify simple pixel-to-world mapping. But if you have perspective distortion, you would need at least 4 points to compute pixel-to-real world mapping (homography - https://decibel.ni.com/content/blogs/kl3m3n/2015/04/24/homography-mapping-calculation-labview-code):
Could you explain the problem more clearly?
K
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,957 Views)
Hi klemen,
Thanks a lot for your reply.
i need to do 2 point calibration .
from my  motion system.  Here i have only X axis .. so i can specify x distance only y will be zero .
(X1,0)  (X2,0).
so i need to calibrate my image using 2 points.
pixel value and x location .. i read from my motion system.
i just pass those points and real world values.
I dont know how to do .. do you have any example file ?
(4,951 Views)
Hi ,
i got it How to calibrate 2 points in Set simple Calibration.
Thanks.
Before i use Set Simple calibration i need to do some calculation (Pixel /mm).
after that i feed into that function ..
(4,921 Views)
