Machine Vision
unable to open the maximum resolution(4872*3248) AVI file in IMAQ AVI Open, is it solved in new version....
Hai friends,
   Already, i have discussed about this problem but still i can't solve this issue......What is the latest version in Vision...  Now i am using 8.6 in which i unable to open the maximum resolution(4872*3248) video file, is it solved in new version....while opening this kind of large resolution video file in IMAQ AVI Open, i have received the error message (  Error -1074395993 occurred at IMAQ AVI Open ).... So please help me....
(3,629 Views)
Can you post a sample AVI file that demonstrates this issue?
Eric
(3,618 Views)
Thanks for ur reply,
                           That AVI file is too large(1.25GB),   so pls take any one picture in the resolution of 4872*3248 (PNG file) and write it in AVI write function then try to RUN the code in Example vi ( Read AVI file)... then you will be able to see the error in AVI open function...
(3,596 Views)
I created an AVI file using the IMAQ Write Frame VI with a few frames of resolution 4872*3248 and was able to successfuly open it using the IMAQ AVI Open function and read frames from it using the IMAQ Read Frame VI. Is it possible for you to crop your AVI file and attach it here? Also, what compression filter do you use?
Vivek Nath
Machine Vision
(3,560 Views)
