Machine Vision
unlisted error code -1074396077
Heres hoping someone can help me learn what the error code -1074396077 means.
It is being return from imaqColorThreshold() version 6.1
Thanx
(3,946 Views)
turboPres -
The error codes should be in the documentation, as well as in the file "nivision.h", for future reference.
That error code means "Incompatible image type", which probably means that you're calling imaqColorThreshold() with a dest image that is not of type IMAQ_IMAGE_U8, or a source image that is not of type IMAQ_IMAGE_RGB or IMAQ_IMAGE_HSL.
Hope this helps!
Greg Stoll
IMAQ R&D
Greg Stoll
LabVIEW R&D
(3,942 Views)
