Machine Vision
usb cam
Hi to you all
I have a question about vision builder ,can i aquire a usb camera with the new vsion builder?  beyound version 3.5
Also another question can i have a text display out to a video out put  like a volume or size of a object so you could see only this on a display , assume a pic has a calc pixel of 560  and i want the number o displayed   at big size stating 560
3 Question  how much is the max resolution  vsion can handle  12 megapixel    50 megapixel    all one image or?.........................
4.Question can it read high speed image´s like 1000 image´s   a   easch second
Thanks for a good answer in advance
(4,030 Views)
Hi cees,
You can acquire an image from a USB camera using the newest version of the IMAQdx driver.
You can use Overlays to place a text display over an image without affecting the image.  Perhaps the custom overlay step might be a good starting point for you.
As far as maximum resolution and image acquisition speed, this is more a question of your computer's specifications.  It depends a lot on how much memory your computer can move around and store all at once.
Stephen Meserve
(3,997 Views)
Hi stephen
Wich version IMAQDX  is the latest?
(3,993 Views)
Hi cees,
IMAQdx 3.4 is the latest.
Stephen Meserve
(3,978 Views)
