Machine Vision
use IMAQdx functions in Labview Communications System Design Suite
I would like to read an image and use the resulting bytes to perform some function. Currently, the system has Labview Communications System Design Suite (2014 SP1)
and Vison Acquistion Software installed. I do not know how to use the IMAQdx functions in labview.  Can anyone help?
Thanks!
(4,711 Views)
Accepted by topic author pradha
I do not work with the Labview Communications System Design Suite.
In LAbVIEW, however, when having installed LabVIEW first and then Vision Acquisition, you can use the Example Finder to locate IMAQ or IMAQdx examples for LabVIEW:  In LabVIEW, select Help >> Find Examples. This will open the Example Finder. On the page "Search", type in the keyword "IMAQ" or "IMAQdx" (according to your camera) and have a look at the examples that come with Vision Acquisition for LabVIEW.
(4,682 Views)
Nowadays, there are some solution for IMAQdx function in Labview Communications System Design Suite?
Or do we have any alternative method to transmit and receive images?
(3,222 Views)
I do have same question.
(3,043 Views)
