Machine Vision
use imaq BCGLookup.vi in 10-bit image
I have used imaq BCGLookup.vi in 8-bit image successfully,but when I use it in 10-bit image such as *.aipd,it doesn't work.Help me please
(2,999 Views)
This function only works on 8 bit images. To use it on your 10 bit images, you would need to convert them to 8 bit first.
You could probably generate a 16 bit user lookup table that does what you need. The brightness and contrast are easy, but the gamma would take a little more work.
Bruce
Bruce Ammons
Ammons Engineering
(2,999 Views)
