Machine Vision
using mindofpete.org to get usb vision, but...
Hi
I downloaded the USB webcam grabber for LV from mindofpete.org. And it works, sort of....
With the standart settings my picture looks a little odd, see the picture attatched. Changing the settings does not make things better!
I desperatly need some help or ideas to solve this problem.
The camera is a Philips ToUCam the LV version is 7.0
J;-)
(3,655 Views)
Hi James,
I have the same problem with a ToUCam II Pro using the mindofpete-library. I want to use the camera for a astronomical project with LV6.1. But if this camera not works I'm trying to get a Logitech QuickCam 3000 Pro. Not so good for astronomy than the ToUCam but better supported (SDK and Labview). I'm interested to get news from you if you have found a solution.
Bye,
Thomas
(3,565 Views)
