Machine Vision
vision acquisition not reading avi file
Hi-- I am currently running LabView 2010 (version 10.0f2) to run the Multi-Worm Tracker (http://sourceforge.net/projects/mwt/).I am currently using the Vision Acquisition Software evaluation version, though I do not have any image acquisition hardware or camera connected; I am only concerned with running AVI files. Everything seems to work perfectly except the program does not appear to "see" the file, even though I am able to select it upon opening without issue.
It appeared to me to run and track images the very first time I ran MWT, though I was not able to see the video at the time. However, it has not worked since that first time. I am curious if anyone out there has thoughts on:
1) Whether or not it is the vision acquisition software that is responsible for this problem
2) If the evaluation version only works once (seems silly as it is good for 30 days... 28 now)
3) What I might be able to do to troubleshoot this
Thanks for your help,
Kevin Burls
University of Nevada, Reno
(4,681 Views)
-Sorry no info on how you are reading avi file?
-It is just an exe. That too looks like it needs lot of other dependencies.(Or am i missing anything??)
-If you need to clarify your doubt on Vision acquisition, just use one of the inbuilt examples in labview for reading avi files and then proceed.
-No, i think evaluation version works untill evaluation time expires.
-You need to provide the code not exe to troubleshoot on more.
uday
(4,670 Views)
