Machine Vision
vision builder or MAX not detecting smart camera 1722
Iam having Ni SmartCamera 1722........also all LabVIEW software with all updates.....
MY problem:     iam trying to connect this camera using ethernet cable(cross cable). but Either MAX or Vision assistant is not detecting.....i also tried to configure using static IP.....
but no use......kindly give some solution or suggest how to proceed on this.......
kindly provide me set of instructions how to  connect this camera
(3,781 Views)
Hi Sunil,
Is the Smartcamera powering on? How have you made the power connections?
Please find below a link which is a details manual on getting started with the SmartCamera.
http://www.ni.com/pdf/manuals/372351c.pdf
(3,754 Views)
Hi voodoo,
Thank you for replying......i have connected smartcamera correctly......the power is on  and camera is STATUS LED is solid glow.....everything is fine..........
still it is not detecting......i think there is some problem with IP address of the camera..........i tried in several computers connecting the camera but it is not showing anything in it.........
can you please tell me how to change IP address of this camera which is by default 0.0.0.0 as per manuals........any other methods to debug this problem......
thank you
(3,740 Views)
Hi Sunil,
Please try the following steps.
- Locate the DIP switches, move the SAFE MODE switch to ON position and reset the camera.
- Open MAX and press F5. The smart camera should showup under remote systems.
- Click on the smart camera - a configuration screen should show up on the right side of the screen
-  Under IP settings select  "use the following IP address:"
-  Enter an IP address which would be compatible with your computer IP address ( for eg the IP address should be in the format 192.168.1.x)
- Apply the settings, move the safe mode switch back to OFF position and reset the camera.
(3,734 Views)
Hi voodoo, I have given smartcamera to hardware department along with your instructions.....now they are taking care of that problem......anyway thank you for support. It will help to resolve the problem.
(3,703 Views)
