Machine Vision
vision builder
I am running an inspection in Vision Builder for Automated Inspection 2011.  I am data logging the results to the local drive and that seems to be working fine.
My question is how do I recall the results?  I'd like to copy the .txt file to a PC so I can do post processing calculations.
(4,673 Views)
You can access these files through FTP communication. Here is a document that describes how to do that in MAX, in the command line, or in the Windows explorer: http://digital.ni.com/public.nsf/allkb/26D4E3A7A05C5F6086256DEF005B20D8
Jeremy P.
(4,648 Views)
