Machine Vision
vision development module
when i  set up  vision development   module i  come across  a problem?
 can you give  me some advice ?
(3,414 Views)
I think you mean the NI IMAQ palette...
For this, install NI IMAQ 3.5(.1) or for FireWire cameras the NI IMAQ 2.0.2.
So that the palette appears in LabVIEW, you must install first LabVIEW and then IMAQ.
If you have installed NI IMAQ first, repeat the installation and enable LabVIEW support.
Otherwise download the driver here:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C0D10?opendocument&node=132070_US
ThSa
(3,392 Views)
