Machine Vision
vision software
To whom it may concern:
I am interested in receiving images from different sources on one chip.  I attached a paper that would explain better of what I like to do.  Basically, the POFD will receive  images from different angles, I would like you to give me recommendation on which camera may be best suited to be programmed with Vision development software.
(3,509 Views)
samybae--
    The type of camera that you need will be determined by what you are trying to do.  We can provide a list of which cameras have been tested to work well with our products.  You can find this list here.
    I am a little unclear how the product you linked works.  Does that work with any standard camera?  How does it connect on?  I sure if you cross reference which types of cameras work with this product against the supported ones on our website you could find one that will work for you.
    Anyway, let me know if you have any questions.
John H
(3,477 Views)
