Machine Vision
vision
I would like to draw lamina in a spine. Therefore I need to set some markers in the image. How can I put them in the image?
I want to draw a perpendicular out of 2 points, I found a option but you need 3 points. Vision has to draw the third point.
(3,129 Views)
Can you post an image?
And You can achieve drawing by using line as an overlay which uses two points only.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,126 Views)
