Machine Vision
webcam labview
I have a related need and I am not sure where the best forum would be to post it. I basically need to design a low cost eye tracking system using a 1394 or usb camera fairly quickly. I was hoping to adapt some of those machine vision VIs that measure size, distance, length etc. to measure the position of the eyes from a live full head image in real time, say at 10fps. Can you give me hints as to where I should post the question, where I can find example codes and how quickly I can do it if it is possible? I use Labview 8.5 and have NI Vision and Vision Assistant 8.5.
Message 11 of 14
(2,977 Views)
if you installed Vision development Module toolkit, there are many corresponding example you can find, just go to search in Example finder of "IMAQ" keyword, or "measurement" somehow. for USB webcam capture, two solution:
1: download "API" 's attachment and register the OCX file, and Call it from ActiveX container.
2:dowload "Kristen H"'s giving link, the IMAQ USB webcam toolkit, this toolkit is nice and easy use.
________________________________________________________
Try to make everything Automatic
Message 12 of 14
(2,975 Views)
if your goal is to work with you ltener vision first note that the programs have a cost, in any case you can use them in mode of assessment and expire over a period of time
You can perform image acquisition only drivers from VAS , but for any treatment or handling or VDM VBAI you need , plus VAS . You can download the evaluation software from the following links :
Message 13 of 14
(1,586 Views)
In this example, we will create a program in Labview to capture images from a USB camera to your application for further processing using the NI Vision module.
https://decibel.ni.com/content/docs/DOC-30531
Message 14 of 14
(1,585 Views)
