Machine Vision
webcam resolution problems with USB IMAQ
Hi. I’ve a problem with a Webcam. I’ve a USB webcam and I use LabView, Vision and NI_IMAQ_for_USB.zip to setup and control the webcam.
When my Labview  program starts it selects the webcam, and asks me for the resolution through a window generated by the own device drivers.
I don’t want this operation as a default, but I want to automatically set the resolution of webcam as 640x480 automatically via LabVIEW..
Some help?
(3,926 Views)
Avoid the second VI (Imaq Usb propertypage). In the first one (Imaq Usb Init) there's a parameter that is the index to the video modes supported by your camera. Try different values and you will see it.
Bye
(3,724 Views)
Thank you for your kind reply, I will let you know if my problems are solved
Regards
(3,720 Views)
