Machine Vision
what video do I need to buy to acquire different types of video signals such as DVI, RGBS,HD_SDI, S-video, Composite, YPbPr onto labview for image analysys.
I need to do image analysis of the LCD screen output and need to acquire different video signals types.
This LCD screen takes different types of video signals as I mentioned in the subject. I need help with what
capture cards do I need to get. Do I need to buy different camera capture cards as some cards accept only
a specific signals, but i NEED ALL. i NEED TO ACQUIRE THESE SIGNALS FOR IMAGE ANALYSIS. I hope to get
reply soon.
Message 1 of 9
(4,704 Views)
Do you need to measure quality of the SIGNAL, or quality of the SCREEN?
Message 2 of 9
(4,699 Views)
I need to measure the quality of the signal for now.
But I also may need measure quality of the display.
thanx for responding so quickly.
Message 3 of 9
(4,697 Views)
Then, I don't believe that you will found single device for measurement.
Probably something from tektronix or other vendor will help you.
Andrey.
Message 4 of 9
(4,695 Views)
The sites and hardware you sugested would it be compatible with labview
for image analysis.
Message 5 of 9
(4,691 Views)
You may want to take a look at these new products from NI, it may cover most of your signal formats and analysis:
Analog (kid)
http://www.ni.com/pdf/products/us/cat_analoganalyzer.pdf
2
Digital (man)
http://www.ni.com/pdf/products/us/cat_digitalanalyzer.pdf
-AK2DM
Message Edited by AnalogKid2DigitalMan on 08-04-2009 11:57 AM
Message 6 of 9
(4,674 Views)
Analogkid2DigitalMan, I have gone through the links you have sent me, but
the boards are sort of analysis tools and I am plannig to build our own image
applications using labview.
Message 7 of 9
(4,667 Views)
Yesh:
Very well. When I read you wanted to measure the quality of the video signal, the VideoMaster software analysis routines came to mind.
-AK2DM
Message 8 of 9
(4,648 Views)
Yes, if you're looking to test the quality of the a video signal, the relevant product from NI is definitely VideoMaster (for the PCI system).
Jeff | LabVIEW Software Engineer
Message 9 of 9
(4,640 Views)
