Machine Vision
where i should get snap vi as i want to use it in another vi
Hi
I am using pci 1411 card . I have installed ni vision . I want to control snapping operation by any key of keybourd.for that
I require snap.vi. according to manual it should present in block called image aquisition. Ihave checked path(fuctions-ni measurments-vision) but i am not able to find it .Help me to find out it.
Message 1 of 9
(5,688 Views)
Maybe you missed to install "NI IMAQ"?
NI IMAQ is part of the  Vision Acquisition Software  which you hopefully got side-by-side with the 1411.
Installing just the Vision Development Module does not install any IMAQ drivers, so this might be the reason why you do not find the Snap.VI in LabVIEW.
Guenter
Message 2 of 9
(5,673 Views)
i  reinstalled the ni imaq again.but stil not able to find out niimq snap vi.
it is not showing image aquisition option in fuction.
Message 3 of 9
(5,608 Views)
What is your lv version and what is your imaq version?
Message 4 of 9
(5,602 Views)
Look at the screenshot, this is how it should appear in the functions palette.
Here is the path on your disk where you should find it once you have installed NI-IMAQ from the Vision Acquisition Software:
LabVIEW x.x\vi.lib\vision\driver\imaqhl.llb\IMAQ Snap.vi
Hope this helps.
David.
Message 5 of 9
(5,590 Views)
for some reason the attachment does not work..
You should find the Snap.vi in
Vision and Motion -> NI-IMAQ -> IMAQ Snap.vi
If you don't see it you have not correctly installed the driver.
Message 6 of 9
(5,589 Views)
my labview version is 7.1
and ni vision version is 7
Message 7 of 9
(5,507 Views)
beside imq vision i have to do one more job the job is i have to take output from two optocoupler one is placed horizontal and one is vertical.the output of optocoupler is 3.2 v for high and nearly 1.2 v for low.i am using pci6014 daq card.labview version 7.1
      can you tell me how i should start with this particular job.
Message 8 of 9
(5,506 Views)
Hi Quary.
You have LabVIEW and you have the Vision Development Module but what you are missing is the driver to get your images from your camera. This driver is included in the Vision Acquisition Software. You should find it together with your framegrabber card from NI. If you don't use NI hardware you need to buy the Vision Acquisition Software.
Here is a compatibility list for the driver (IMAQ for framegrabber-connected cams, IMAQdx for IEEE1394 and GigE)
http://digital.ni.com/public.nsf/allkb/6B55FF09D1FBD3108625719600650B7C?OpenDocument
To answer your DAQ question I suggest that you open a new thread in the DAQ forum.
David
Message 9 of 9
(5,494 Views)
