Machine Vision
which digital camera is suitable for the pci-1422
when i purchase a digital cam for PCI-1422 , what should i focus on, for example: Resolution, interface, depth of color or etc??
How to classify the a digital cam and how to identify which is suitable for PCI-1422??
Does anybody have recommandation for me!!??
thanx!!!
(3,258 Views)
There are a lot of digital cameras that work well with the PCI-1422.
Selecting the proper camera depends more on your application than the PCI-1422. You need to look at resolution and frame rate, along with bit depth, color or B&W, etc.
You will also need to select a lens that matches your application. You might just need a fixed focal length, or you might need a zoom, a telecentric lens, or other possibilities.
I would recommend discussing your application with Robert Eastlund of Graftek Imaging (800) 441-2118. He will be able to help you select the proper camera and lens for your application.
Bruce
Bruce Ammons
Ammons Engineering
(3,258 Views)
