Machine Vision
why can't i transfer .DLL file to cvs1450?
hello,I have a cvs1450.I want to transfer a DLL file to the target through FTP in MAX  .But there is an error"I/O error",and the file can't be sent.what's wrong?thank you very much.
(3,595 Views)
(3,594 Views)
(3,593 Views)
I have  ftp this DLL to the CVS and put it into the directory that is referenced by the path in my Call Library Node. But there is also an error called"failed to loaded ……".
(3,571 Views)
