Machine Vision
why does my Usb camera acquire zoom-in images?
Hallo, all,
I am using Logitech quickcam Pro9000 and IMAQdx (setup vi,grab.vi) to get image. But i always get zoom-in images. I tried IMAQ USB, I can get clear and original size images,but the problem is when I stop the program by clicking the red circle button on tool bar, my labview 8.6 will be totally shut down.  I think, IMAQdx is the best way to get images. but why does the camera always get the zoom-in images? does anybody know the reason? By the way, does anybody can tell why the problem happened in the case of IMAQ USB ?Moreover, can anybody suggest a method to configure the camera by labview? Thank you very much!
(3,037 Views)
1.By clicking red button - Its not a good practice to stop the vi. Use stop button to exit from your program.
2.Zoom - Have u ever changed the zoom in the lens or zoom tool in the image display window, if not so you can set the camera property using property nodes in the vi.Capture.PNG
Silver_Shaper | CLD
(3,029 Views)
